Syvecs pnp tfsi
Posted: Wed Sep 06, 2017 5:57 am
by GLDN6
Hello,
I'm going to buy a syvecs for my tfsi engine. pNP
however, I still have a few questions.
- can lambda control be cut off?
-where I can enter the injector dead times.
-where I find the coil dwell times table
Does anyone have a standart map for tfsi engines?
Best regards
Re: Syvecs pnp tfsi
Posted: Wed Sep 06, 2017 6:14 pm
GLDN6 wrote:Hello,
Best regards
1. Yes, but not sure why you would want to ?
2. In the Fuel corrections menus
3. In the ignition corrections menus
If you buy the ecu, presumably it will come with a base map that will run your engine, as do all plug n play kits. If not, email Syvecs support and I'm sure they can oblige.
Re: Syvecs pnp tfsi
Posted: Wed Sep 06, 2017 6:20 pm
by GLDN6
Hello, thanks for the answer.
until today I have only kms ecumaster emu and adaptronic worked.
at syvecs the names are quite different
but I have not found one yet
This is about the crankshaft sensor and the camshaft sensor.
how are the settings made?
Best regards
Re: Syvecs pnp tfsi
Posted: Wed Sep 06, 2017 6:25 pm
GLDN6 wrote:Hello, thanks for the answer.
Best regards
You have not found what yet ?
And what is about the crank sensor and cam sensor ? What settings or what are you trying to do ?
Re: Syvecs pnp tfsi
Posted: Fri Sep 08, 2017 1:26 pm
by GLDN6
How i set The trigger for The cam and crankshaft..
The pnp loom it is compatibel with The Bosch med9.1 ?
Best regards
Re: Syvecs pnp tfsi
Posted: Fri Sep 08, 2017 4:22 pm
If you buy a plug n play kit, it will simply fit into the car and start and run.
You should not need to configure any crank or cam settings as all this will already be done.
But mostly settings relating to either will be in either Sensor menus, or in Engine Configuration menus.
For specific fitments, best to email Syvecs
support@syvecs.co.uk
