DCCD wiring / pin question
dr_jones
Post by dr_jones »
Hi have a DCCD wiring / pin question as is relateds to the S6Plus.
My pinouts are configured as:
H-Bridge7 / SlaveOut7H-Bridge7 / SlaveOut7H-Bridge7 / SlaveOut7 --> DCCD+
H-Bridge8 / SlaveOut8H-Bridge8 / SlaveOut8H-Bridge8 / SlaveOut8 --> DCCD-
In terms on ECU I/O config, am I simply assigning:
Outputs: Diff Pressure Control (Centre) --> SLAVE1 OUT #7
As I dont see anywhere on the I/O where I could viably connect my DCCD- at all
If that is the case how does the ECU 'know' whats hanging off SlaveOut8?
Finally - I read here that non coil driving outputs (ign) require an additonal schottky diode installed - I'm assuming that these SLAVE 1 out #7 would not being a general purpose output.
