Yaw or Lat G for FWD traction control
Posted: Sat Jun 17, 2017 2:10 pm
by Mark_r33
I've been pondering the sensors I'm going to need for my car recently and am looking for some advice on what the best sensor would be for varying the TC slip% on a FWD car?
I know that Yaw is listed as being the recommended sensor, which seems perfect in a RWD application, but I'm not so sure on FWD?
In RWD if you overpower the drive wheels you would generally get increased rotation, hence the use of Yaw, however in a FWD the inverse is generally true, you would reduce rotation rate, so Yaw would then not make sense to me?
With the above in mind I am thinking that Lat G is probably the more useful sensor here?
Thanks in advance for any help
Re: Yaw or Lat G for FWD traction control
Posted: Sat Jun 17, 2017 3:17 pm
Trial...error...
For each and every individual application.
Posted: Sat Jun 17, 2017 6:18 pm
by Mark_r33
What do you use with yours?
I'm thinking Lat G currently, but am going to use one of the Bosch sensors that has both Yaw and LAT G in one unit so I can try either.
Be nice to know from some other fwd guys what they have ended up using
Posted: Sat Jun 17, 2017 7:30 pm
I dont have a Yaw sensor, so it is LatG.
That said, I dont vary it much anyway, and keep a pretty tight reign on traction...for safety reasons.
I may vary it at some events, purely to allow some wheelspin to allow the car to try and slide a little...but only a little ! lol But I need to do a run or two first to see what sort of speeds/loads I'd be doing on any particular corner I felt it might be safe to allow more wheelspin
