Knock Warning Output Behaviour?
Posted: Fri Apr 10, 2009 9:08 am
Hi,
I have a LED indicator which is grounded by the knock warning out put, I'd like to know what condition is needed to be met in order for it to flash, and to remain illuminated until ECU reboot.
Logic would suggest to me that it's something along the lines of, it flashes if any knock is detected/ignition pulled; and stays latched on if when the amount of retard defined in 'Sensors - Knock Warning light - Ignition Retard Threshold for Knock Warning Output' is met/exceeded.
Is that right?
Jezz.
Is that right?
Jezz.
