Software fixes - SCal
Slowie
Post by Slowie »
Hi guys
I have noticed two small bugs in SCal, maybe these can be addressed.
In Drive By Wire/Limp Mode Limit/Maximum Target, ECT Trip is listed twice. I guess it is supposed to be ECT and ECP trip.
Secondly, if I view Drive By Wire/Minimum Target In Crank or Minimum Target In Run, then view another setting, and press Z to return, it returns me to Idle Stepper Control/Minimum Target In Crank or Idle Stepper Control/Minimum Target In Run, respectively. Small annoyance, but it led to some confusion when using the shortcut keys.
Re: Software fixes - SCal
Have made software team aware
Slowie
Post by Slowie »
Slowie wrote:Secondly, if I view Drive By Wire/Minimum Target In Crank or Minimum Target In Run, then view another setting, and press Z to return, it returns me to Idle Stepper Control/Minimum Target In Crank or Idle Stepper Control/Minimum Target In Run, respectively. Small annoyance, but it led to some confusion when using the shortcut keys.
I have an update on the above. It applies to any situation where there are more than one table/map with the same name. If you press Z to go back, it will always take you to the first one encountered from the top of the tree in SCal, e.g. I look at Starting/Fuel Multiplier, go to a different screen, press Z, and it takes me back to Gear Cut/Ramp Out/Fuel Multiplier.
