Default Calibration for S6 with Advanced Knock?
jezzpalmer
Post by jezzpalmer »
Hello,
This is my first of no doubt many posts; most of which will probably be annoying questions.
I have ordered an S6GP with Adv Knock through Jez at H-Dev, however I currently have some free time so have started to construct my calibration file.
I've been working on the default S6 calibration (1.6.1), though it appears this doesn't have the adv knock settings, is that correct or am I missing something?
Is it possible to get an adv knock calibration file, or alternatively will I be able to port what I've done on the std calibration to the advanced knock one once i receive the ECU and get it powered up?
I don't want to spend more time on the std calibration and not be able to use what I've done, but I do want to get the bulk of the initial setup done in the meantime.
Jezz.
Charlie
Syvecs Staff- Tea Boy
Re: Default Calibration for S6 with Advanced Knock?
Post by Charlie »
Hi Jezz,
There should be no problem with using the default cal, when you plug it into your ECU the full knock should pop up.
However, just to be safe, Pat will fire over a full knock cal file to you tonight.
Regards,
Charlie
jezzpalmer
That would be brilliant, thanks. :)
Jezz.
You have PM :)
Sorry about the delay.
jezzpalmer
Thanks very much, Pat. :)
