Gents,
First an apology for some incorrect information. It looks like the pattern *IS* supported and I had suffered a brain fart. Here's how to do it
The pattern is 36-2-2-2 with the following gaps :
18x 10 degrees
1x 30 degrees
9x 10 degrees
2x 30 degrees
We can trigger off this with the Single Gap strategy *WITH* gap validation. This will search for a unique sequence of short-long-short gaps and that occurs only once in this pattern - the last 10 degree gap before the lone 30 degree gap and then the first 10 degree gap after the lone 30 degree gap. The two lots of 30 degree gaps would not meet the search criteria and would not be used as a datum.
There is a requirement that in the gap definitions, the unique long gap must be entry #1 and entry #0 must be a short gap. So we need to slide this pattern into the correct sequence :
30 gap definitions, with angles:
10,30,10,10,10,10,10,10,10,10,10,30,30,10,10,10,10,10,10,10,10,10,10,10,10,10,10,10,10,10
Minimum gaps
5,15,5,5,5,5,5,5,5,5,5,15,15,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5
Maximum gaps
15,45,15,15,15,15,15,15,15,15,15,45,45,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15
Gap Ratio and Gap Validation Ratio should be fine at around 2.0
The reference is the tooth after the tooth after the tooth that ends the gap (one ends the gap, the second validates the gap by proving it is short again, then the last tooth is the reference). In this case it is the third tooth in the group of 9 equal gaps. Legend has it that TDC is the fifth tooth in the group of 9 equal gaps, which would be the fourth gap and therefore 2 gaps on from the reference tooth. That would place the reference tooth at 20 degrees BTDC so the reference angle would be 340 degrees. Hopefully I got that right
The EJ motors use 4-X teeth for the AVCS angle measurement. On the G11 engines X is zero (no missing teeth) and they get the phase information from a different sensor. On the later engines (late-G11 / G12?) X is one tooth and it is possible to get phase from the AVCS. On the EZ engines it looks like the cams might be 3 equally spaced teeth. That being the case, they are 240 degrees apart and not matter what you do you always end up with 2 in one phase and 1 on the other so you can get phase from this as long as the AVCS doesn't swing it so far as to move one tooth from one phase into the other - if this happens then disable phase verification in 720 - most cams park themselves until VVT solenoids are enabled so they should be in a well defined position prior to AVCS operation.
