Worksheet and Layout Export/Import
Posted: Mon Jan 04, 2016 8:37 am
by KulinPapa
Could it be possible to make Exportable and Importable the Gauge Layouts in SCal, and the Worksheets in SView ? It takes several hours to migrate the settings when needs to change to a new laptop.
Re: Worksheet and Layout Export/Import
Posted: Mon Jan 04, 2016 3:09 pm
Hi there!
I believe this is on the ToDo list, you're not alone in requesting it so watch this space
In the meantime you can probably achieve the result that you want by copying the registry tree for the SCal application from the original machine to the one that wants a copy of your settings. Less user friendly but it will save some time.
Posted: Mon Jan 04, 2016 9:38 pm
See here, it doesnt take hours...but it does still need a proper solution
viewtopic.php?f=19&t=678&p=3603
