MAP Sensor readings
Posted: Thu Sep 10, 2015 9:36 pm
by Arch
What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
Re: MAP Sensor readings
Posted: Thu Sep 10, 2015 10:25 pm
Arch wrote:What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
Atmospheric should be around 1000mbar, give or take.
Posted: Thu Sep 10, 2015 11:01 pm
and at idle, 200-600mBar usually.
Posted: Fri Sep 11, 2015 8:14 am
by Arch
Thanks guys appreciate the help
