Preferred Crimper?
Posted: Tue Jun 02, 2015 5:45 pm
by Bikey
Apologies if this has already been covered (I couldn't find anything)- what is the preferred crimping tool(s) for the S8 connector pins? Is something specific needed or will something like the Paladin 2033 or a Metripack crimper work well?
Re: Preferred Crimper?
Posted: Tue Jun 02, 2015 7:49 pm
I would try those two tools and see what the crimps are like. I use a Durite tool intended for junior and microtimer terminals and that does a great job for around £50.
Posted: Thu Jun 11, 2015 7:41 pm
by JamesD
I've used a cheap WeatherPack/MetriPak crimper (like the one DelCity sells) to do a few connectors quite successfully.
Now that you posted it I might buy the Paladin die just to try it out.
Posted: Tue Oct 27, 2015 8:34 am
by skylion
TimH wrote:I would try those two tools and see what the crimps are like. I use a Durite tool intended for junior and microtimer terminals and that does a great job for around £50.
Is it one of the following?
http://www.gsparkplug.com/durite-ratche ... 03-52.html
http://www.gsparkplug.com/durite-ratche ... 03-53.html
Posted: Tue Oct 27, 2015 11:39 pm
The second of those (for JT terminals rather than JPT).
Posted: Thu Oct 29, 2015 6:21 pm
by skylion
TimH wrote:The second of those (for JT terminals rather than JPT).
Thanks Tim
