EGT Calibration ?
For sharing Syvecs Engine Control Calibrations.
EGT Calibration ?
Should all K type probes be the same ?
I bought one of these to use, https://shop.vems.hu/catalog/sensor-type-p-53.html
But the only EGT in the Sensor DB lists a Texense 1250degC unit
This seems quite off with this probe, readings also seem erratic. Ambient sits at around 70degC
When running temperatures are sky high, over and above anything sensible
Re: EGT Calibration ?
EGT linearisations are normally for non standard responses, a flatline 0 everywhere in the linearisation table is used to signify a standard sensor.
