BAC Idle Frequency?
Posted: Thu Feb 27, 2014 10:56 am
by C. Ludwig
Where does one adjust the frequency of the PWM output for BAC idle control? Only setting I can find is under Idle Stepper Control > PWM Frequency. Thanks!
Re: BAC Idle Frequency?
Posted: Thu Feb 27, 2014 3:22 pm
by pavlo
Have you looked at the "Throttle Bypass Valve" menu?
The output should also be configured as "Throttle Bypass valve A" unless you have a 3 wire valve in which case you can configure outputs A and B for each side in a push/pull setup.
Posted: Fri Feb 28, 2014 10:27 am
by C. Ludwig
Thank you. Makes perfect sense once it's right in front of you. :)
