ignition lock
secure
ignition lock
Post by secure »
Ignition lock for measuring with a timing light.. Am i missing?
Re: ignition lock
Yes you are missing the fact there isn't one and you have to do it manually.
Create a separate flat ignition map (select with calibration switch or similar), temporarily fix all ignition compensations ESPECIALLY idle speed ignition control.
secure
Re: ignition lock
Post by secure »
The fact is I am lazy =)
I thought there was a feature under the output testing settings. Anyway.. Thanks!
