Using fuel temp sensor to trigger a fan on a fuel cooler
Posted: Thu Aug 29, 2013 5:16 pm
by legacygtb
As title really, getting a bit of heat soak into the fuel system, is it possible (are the channels etc there) on an s6pnp to trigger a fuel cooler fan at a preset fuel temp?
Re: Using fuel temp sensor to trigger a fan on a fuel cooler
Posted: Fri Aug 30, 2013 2:24 pm
Had a quick look, and I can't see any way to do this on an S6, although it would be easy on an S8 :(
Posted: Fri Aug 30, 2013 8:12 pm
While maybe awkward.
use the brake light output and configure the temp sensor to the relevant input ?
The numbers wont make sense, but it should function.
Or likewise Nitrous bottle heater function via Nitrous pressure input.
Posted: Fri Aug 30, 2013 8:14 pm
Excellent lateral thinking there - like it :)
