Using fuel temp sensor to trigger a fan on a fuel cooler
legacygtb
Post by legacygtb »
As title really, getting a bit of heat soak into the fuel system, is it possible (are the channels etc there) on an s6pnp to trigger a fuel cooler fan at a preset fuel temp?
Re: Using fuel temp sensor to trigger a fan on a fuel cooler
Had a quick look, and I can't see any way to do this on an S6, although it would be easy on an S8 :(
While maybe awkward.
use the brake light output and configure the temp sensor to the relevant input ?
The numbers wont make sense, but it should function.
Or likewise Nitrous bottle heater function via Nitrous pressure input.
Excellent lateral thinking there - like it :)
