Wiring CAN
Posted: Thu Jul 18, 2013 8:27 am
Hi I am about to wire the the Syvecs S8 to the Racetechnolgy Logger DL1 Mk3 and would like some help.
The logger has a DB9 male connector with CAN H and CAN L to connect to.
The distance from the logger to S8 ecu is maybe max 30cm, so should i connect it directly by wiring the S8 CAN H and CAN L using a female DB9 and just that or i need to add a resistor between CAN H and CAN L for the system to work, as it seems that the cable must have a certain resistance to work properly.
Thanks for help.
Thanks for help.
