Gear Cut/Shift on full throttle
Posted: Mon May 27, 2013 5:06 pm
Hi, I am thinking of fitting a strain gauge gear knob for full throttle shifting and to ease some strain on the dog gears during shifting and would like some clarification on the setup.
This is the link of the gear knob which i was thinking of using.
http://flatshifter.com/strain-gauged-gear-knob/
It seems that that are 4 options on the output from the amplifier so to feed the ecu and was not sure which one is best for me.
A) I will set the i/o Input to Gear Shift Manual Cut Request
B) Gear shift mode to manual
C) Cut input Nominal rest voltage is what i am concerned as not sure which voltage is best from the gear knob amplifier to have for the Syvecs for sure below 0v not good.
D) Pushing and Pulling seem to have different voltages and not sure if i can use it like that?
Has somene tuned something similar please?
