CAN BUS Cal Switch
Posted: Mon May 20, 2013 8:38 pm
I currently have a S6 in my Supra and I have added a DBW setup which Ryan has been helping me with. I have also added some additional sensors for the ECU to monitor and display on a Dash2 via the CAN BUS.
It appears I have now used all the inputs on the ECU (I need to check with Ryan that I haven't cocked up somewhere when he is available) so was wondering if it was possible to use something like this to scroll through cal switch settings. (Positions are displayed on the Dash2 anyway).
http://www.digitalswitchingsystems.com/ ... on_Web.pdf
I was thinking just having + & - buttons for Engine Configs and + &- for Trac settings. The PKP2200 would do nicely.
It appears they are fully programmable and have plenty of CAN options so hopefully they could be configured to talk to the Syvecs which can then set the cals as needed.
Or is there something already available to do this? I saw some Cal options in the Custom CAN settings which hopefully can be configured for this.
Steve
Steve
