AVCS Wiring S6 PnP
Posted: Tue Apr 02, 2013 9:54 pm
by Pedro
I am about to do the avcs wiring for the STi8 JDM heads but i have some questions, should i use shielded cables from the sensors to the ecu? What diodes should i use for the solenoids?
Re: AVCS Wiring S6 PnP
Posted: Tue Apr 02, 2013 11:17 pm
Yes...and 3A or 5A schottky diodes. I use SB560, Pat uses 1N5822 but either will be fine.
Posted: Thu Apr 04, 2013 3:00 pm
by Pedro
Thanks Tim ;)
Posted: Tue Apr 16, 2013 7:33 pm
by Pedro
Can the spare ignition outputs be used to drive the avcs solenoids?
Posted: Tue Apr 16, 2013 7:56 pm
Nope! They are logic-level drivers designed for ignitors.
Posted: Tue Apr 16, 2013 8:18 pm
by Pedro
Thanks, so, i suppose i can only use INJ5 and INJ6 correct?
Posted: Tue Apr 16, 2013 8:22 pm
INJ or AUX outputss. You may be able to get external widgets to convert the low current logic/ignition drivers to something that will drive solenoids...not sure, as I've never looked!
Posted: Thu Apr 18, 2013 2:22 pm
by pavlo
You could use an ignition amp no problem, they are afterall designed to drive coils!
