Wideband wiring
Jez
Horsham Developments
Wideband wiring
Post by Jez »
I'm currently using a wideband interface that communicates to the Solaris via a 0-5v signal wire.
I'd like to remove this gauge and connect the WBLS directly to the Solaris.
Would this be the correct wiring:
Code: Select all
Solaris        - WBLS
WBLS signal    - Vs
WBLS pump      - Ip
WBLS ground    - Vs/Ip
WBLS heater    - H-
+12v           - H+
Re: Wideband wiring
Hi Jez
Which sensor are you using?, As if its an LSU4 they are currently not support.
I know solaris are working on this but the heater calibrations for the LSU4 is not easy to setup compared to the NTK units.
If its an NTK sensor then it will work no problem
Ryan
Jez
Re: Wideband wiring
Post by Jez »
Hmmm... I'll have to check - I think it may be an LSU type...
Jez
Re: Wideband wiring
Post by Jez »
Anyone got a good source for the NTK sensors?
Re: Wideband wiring
Im sure Pat has some spare :)
