ALS, Gear Cut/Blip, Launch Control
Posted: Mon Jan 02, 2012 6:40 pm
Hi there,
I have finally come around to start doing some more testing with several features.
I have started with Launch Control. At first there was no Clutch switch signal so I told the ECU the clutch was active LOW just to get it to go into LC mode and do some tests. After I wired in the Clutch signal and all is good now. I still have a question regarding the LC strategy. At the moment it seems it is using a retard and mostly Fuel cut to prevent Revs from rising above target RPM too much. Whilst popping and banging waiting for boost to increase AFRs are very lean due to Fuel cut. Is this safe? Is this the normal practice for LC? I don't have much experience with other ECUs besides HKS Fcon Vpro where they do not do a fuel cut but rather retard the ignition a lot and have an actual ignition CUT with a hysteresis to keep the RPMs from rising. This keeps AFRs more sensible. However maybe I am too worried and appearing AFRs are not what they actually are when using LC...... Any advice/thoughts/comments?
Next was ALS. I have wired my K-type EGT sensor into the ECU for this. The ALS offers basically 3 things to play around with. Fuel cut and Ignition retard as well as target TPS. The base settings that were in the ECU when I got it seem to be VERY MILD and whilst it does sputter and pop a bit it doesn't bang and almost doesn't generate any boost. If any it reduces vacuum by a bit. I have tried to get more air into the engine by increasing the target TPS upto 20% and adding a bit of fuel as well as retarding ignition more. It works as it puts me into the 0 Bar range when idling at 2k RPM thereabouts when activated but it still doesn't generate any proper boost and/or large bangs which normally should create lots of exhaust energy to get into boost at idle. Any ideas/thoughts/comments?
Personally I feel there should be the ability to have a ignition CUT as a percentage (as a rotational cut... EG 50% = Fire cylinder every other power stroke) to get more fuel into the exhaust without increasing revs too much and have larger explosions. The same should perhaps apply to the Launch Control to have this ability.
Next on the list was Gear Cut to do FFS on the car. I am not quite sure how to set it up and what type of inputs are needed for it. I figures I needed a Clutch signal so I tried that but that doesn't seem enough. After I saw there was a seperate Gearcut Request option which I then set to the Clutch signal on the same Input. That was not allowed and the ECU said that input was already used on the Clutch Switch. I then set the Clutch switch to another input and set the active LOW to make sure the Clutch was always Depressed and set the Gearcut Request to the actual Clutch signal..... still no success. Am I missing something? How should this be setup to work properly?
Next on the list is to do Gear Blip but I have seen on this forum that isn't something very simple apparantly. What would be needed to get it to work on a DBW Hawkeye with a Manual H-pattern box? Is it possible at all?
Jasper.
Jasper.
