Page 1 of 2
Stack data stream addition
Posted: Sun Dec 11, 2011 6:26 pm
by ScoobyDuck
Any chance there could be a custom stack datastream element of the calibration switch position?
cheers
Steve
Re: Stack data stream addition
Posted: Mon Dec 12, 2011 10:03 am
by secure
Hey Steve
Do you mean that?
http://www.youtube.com/watch?v=2bot4jGzMHw
If so, you should activate it from SConfig.
Posted: Mon Dec 12, 2011 12:46 pm
by ScoobyDuck
Cuneyt
no, not quite. what i mean is, as a parameter that is sent down the stack serial data stream.
there are standard things like RPM, LAM, OIL P & T etc but nothing to say what CAL you're in. which, if the switch were to fail, or get knocked you wouldnt know.
i know its on the CAN parameters but im looking at it for on the STACK serial steam.
Steve
Posted: Tue Dec 13, 2011 2:08 am
The Syvecs team will need to confirm, but I think you may find that there's an update on its way that will provide a whole heap more info via RS232. Not necessarily an update to the existing STACK stream, but via RS232 nevertheless.
Posted: Tue Dec 13, 2011 12:23 pm
by ScoobyDuck
Tim
Thanks for that snippet. there seems to be some good work going on behind the scences in the way of features (and products
) soon to be launched.
Can anyone confirm what this change to the protocol(s) might be?
ta
Steve
Posted: Mon Apr 02, 2012 11:21 am
by ScoobyDuck
With the new release you can push CAN data through RS232 but can i get this request in for the STACK data stream please?
cheers
Steve
Posted: Tue Oct 30, 2012 11:15 am
by Wez
ScoobyDuck wrote:With the new release you can push CAN data through RS232 but can i get this request in for the STACK data stream please?
cheers
Steve
Can you not create a new custom RS232 stream like the STACK stream with the addition of CAL position?
If the STACK stream was altered it would no longer be a STACK stream.
Posted: Tue Oct 30, 2012 1:03 pm
Why not use the CAN-over-RS232 option (i.e. custom serial)? Much more flexible
Posted: Tue Oct 30, 2012 1:39 pm
by ScoobyDuck
no you cant Wez
and no, it will still be STACK, it will just have additional data in it, each defined by a unique ID.
And no i cant Tim, because my interface is a tiny 8bit thing which can barely cope with the rs232 let alone the processing to get the data out of the CAN packets.
so I just wanted 1 extra bit in the STACK data.
I spoke to Ryan about this and he said it was possible and would try to add it for the next release but that was some months ago now.
Steve
Posted: Tue Oct 30, 2012 5:07 pm
The custom RS232 is at 115.2k rather than 1Mbit/s of CAN, so I would think your 8 bit micro should probably cope? The protocol is very straight forward - think of it as like STACK but 10 times faster.
