Page 1 of 2
Wire oil temp and pressure to S6PnP
Posted: Fri Aug 19, 2011 2:11 pm
What is the recommended method for wiring additional sensors to the S6PnP? Where do you access the unused inputs - I assume they do not appear on the main ECU PnP connectors?
Re: Wire oil temp and pressure to S6PnP
Posted: Sat Aug 20, 2011 11:33 pm
by secure
Which inputs do you refer? Are you referring the auxiliary inputs backside of the ECU?
I think they can only be activated by a firmware upgrade which has never been released yet.
May be sometime..
Posted: Sat Aug 20, 2011 11:39 pm
If I look at the IO configuration and try and assign an input for (say) Oil temp, I have the following to choose from:
AN-06 (5V/TH): CTL038
AN-07 (5V/TH): CTL040
AN-08 (5V/TH): CTL042
AN 11 (5V) :CTL-047
So...where are those connections?
Posted: Mon Aug 22, 2011 12:58 pm
by ScoobyDuck
they are dependant on your MY of car if its a PNP
check the thread on the pin outs at the top of this forum.
Steve
Posted: Mon Aug 22, 2011 10:54 pm
Unless I've misread it the only pins are on the AUX connector and they're outputs not inputs?
Posted: Tue Aug 23, 2011 3:47 pm
by ScoobyDuck
Tim
AB1-4 are called AN1-4
AU1-4 are called AN5-8
AV1-4 are called AN9-12
AR1-4 are called AN13-16
so for me (My97)
AN-06 (5V/TH): CTL038 = AU-02 = O2 signal (ecu plug =B5)
AN-07 (5V/TH): CTL040 = AU-03 = MAF Signal (ecu plug =B6)
AN-08 (5V/TH): CTL042 = AU-04 = test mode connector (ecu plug =B21)
AN-11 (5V) :CTL-047 = AR-03 = Read Memory (ecu plug =B2)
so i think these'll be the same for yours (although different ECU wire, if different MY) as you're probably not inputing a NB signal, or a MAF, or using the test or read mode connectors?!?
cheers
Steve
Posted: Tue Aug 23, 2011 3:55 pm
OK, so subject to checking the nomenclature, you're saying I need to redeploy unused pins on the main ECU connectors (e.g. MAF signal)...which makes sense, but I had (naively) hoped that unassigned pins as per the CAL might appear somewhere helpful on the ECU, other than having to hack the loom to re-use inputs that I don't need.
Thanks for the help
Posted: Tue Aug 23, 2011 6:57 pm
by ScoobyDuck
unassigned is exactly that!
They are by design pins on the connector. you just assign what function they are doing inside the ECU.
So for example the AN7 (AU3) MAF connector can have an AIT plugged into it. So in the ECU you define AIT1 as AN7.
so yes, re-deploy.
Somewhere I'm sure Pat wrote about using DEFi senders, already connected to the DEFi controller, just punching the VSig
not sure if this might be of help also (commision lol)
http://bbs.22b.com/cgi-bin/ultimatebb.c ... 7;t=001186
Steve
Posted: Tue Aug 23, 2011 7:06 pm
Thanks Steve - wasn't the CAL side of things that bothered me, just hoping there was a better way of accessing the pins instead of bodging in to the car loom. But a bodge it will have to be
Looking at the '01 onwards it looks like there are only 3 spare that I can use: MAF, and the two TGV inputs (inputs? Hmmm, thought they'd be outputs but then since I don't have any what do I know!). I'll get the cutters out lol.
Posted: Tue Aug 23, 2011 11:11 pm
by ScoobyDuck
cut or find some plugs for the other side
