S6 running with SR20DET
Posted: Mon Aug 18, 2008 8:26 pm
by Jez
Just got to sort out the cold start, figure out why I'm not getting a speed reading from my ABS sensors and get some pins from somewhere so I can get my boost control solenoid wired up.
Re: S6 running with SR20DET
Posted: Tue Aug 19, 2008 7:12 pm
by Ryan.g
Good stuff Jez
Is this in your TA car?
Posted: Tue Aug 19, 2008 8:44 pm
by Jez
Yup - should be good
Got the cold start and closed loop lambda control sorted this evening
Posted: Thu Sep 18, 2008 9:30 am
by Ryan.g
How did mapping go Jez?
Posted: Thu Sep 18, 2008 9:58 pm
by Jez
Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun
Posted: Thu Sep 18, 2008 10:24 pm
by Wez
Jez wrote:Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun
You had chance to try it in anger or you waiting for abingdon?
Posted: Fri Sep 19, 2008 9:24 am
by Jez
Not tried it properly on the road or track yet. I have been for a quick blast though and its chuffing quick.
