Wideband lambda, and connectors
I've looked through the various threads on here, and I think that the consensus is that the L2H2 is the only lambda sensor that is a) available and b) likely to work as expected on the S6PnP. Is that right?
If so, where is a good place to get one? And what are the connector types I need both at the ecu end, and for the lambda itself?
Charlie
Syvecs Staff- Tea Boy
Re: Wideband lambda, and connectors
Post by Charlie »
Your local Syvecs dealer will be able to get one from us Tim, we have connectors and everything
Thanks Charlie.
My local Syvecs "dealer", aka JGM ;) says I should ask you Charlie :) Can you PM me a price for an NTK L2H2 and mating Syvecs connector please?
Sorted both myself.
