Sensor failure detection
Posted: Thu Mar 10, 2011 12:29 am
Can someone explain how the sensor failure detection works?
In particular what I'm looking at is the EGT sensor. I understand about the failure rate and recovery rates and the default high and low voltages, but in this instance, how do the too low temp, too low time and too low run time settings work?
Basically the problem is that my EGT sensor is showing as failed when I first power on, but I think it's just because it's not up to temperature. Looking at the voltage the sensor definitely appears to be working.
Also, it's been hinted at in a previous thread, but can someone confirm that when using the k-type thermocouple sensor input, an internal calibration is used rather than the 0-5 volt linearisation curve or not?
Thanks!
Thanks!
