Cat5 Wiring
Posted: Fri Aug 01, 2008 11:10 pm
by Ryan.g
Howdy
Would the Staff cleaner on here be able to help me
Just sorting the pinouts for the MR and could you possibaly help with the pinouts for the cat5 wiring. Totally forget how we did it on the supra
Here is a diagram on the cat5 pins to help explain which pins on the s6 go to which pins on the RJ45 connector
Ryan
Re: Cat5 Wiring
Posted: Sat Aug 02, 2008 10:03 am
by pat
Standard Ethernet wiring is :
Pin 1 - Transmit + - Goes to Receive + on Solaris
Pin 2 - Transmit - - Goes to Receive - on Solaris
Pin 3 - Receive + - Goes to Transmit + on Solaris
Pin 6 - Receive - - Goes to Transmit - on Solaris
In effect you're making a crossover cable to be able to plug straight into a PC.
Don't forget that you needs pairs on 1&2 and 3&6 !
Edit : Typo (Pin 6 read Pin 4 previously)
Re: Cat5 Wiring
Posted: Mon Aug 04, 2008 9:04 pm
by Wez
Not wishing to sound stupid Pat but you listed Pins 1 to 4 above and said use pins 1&2 and 3&6 or am I missing something.
Should 3&4 be 3&6?
Re: Cat5 Wiring
Posted: Tue Aug 05, 2008 3:49 am
by pat
Should 3&4 be 3&6?
Yes. Typo. My bad! I will edit the above so that others that look don't end up wiring it wrong.
Re: Cat5 Wiring
Posted: Tue Aug 05, 2008 10:24 am
by Ryan.g
Glad you mentioned it Wes
Didn't want to post just incase it was right and i was being stupid
p.s Pat get to bed earlier (3.49am) stop waiting for television x to start
