Cat5 Wiring
Cat5 Wiring
Howdy
Would the Staff cleaner on here be able to help me :mrgreen:
Just sorting the pinouts for the MR and could you possibaly help with the pinouts for the cat5 wiring. Totally forget how we did it on the supra :lol:
Here is a diagram on the cat5 pins to help explain which pins on the s6 go to which pins on the RJ45 connector
Ryan
Re: Cat5 Wiring
Standard Ethernet wiring is :
Pin 1 - Transmit + - Goes to Receive + on Solaris
Pin 2 - Transmit - - Goes to Receive - on Solaris
Pin 3 - Receive + - Goes to Transmit + on Solaris
Pin 6 - Receive - - Goes to Transmit - on Solaris
In effect you're making a crossover cable to be able to plug straight into a PC.
Don't forget that you needs pairs on 1&2 and 3&6 !
Edit : Typo (Pin 6 read Pin 4 previously)
Wez
Santa's Little Helper
Re: Cat5 Wiring
Post by Wez »
pat wrote: Don't forget that you needs pairs on 1&2 and 3&6 !
Not wishing to sound stupid Pat but you listed Pins 1 to 4 above and said use pins 1&2 and 3&6 or am I missing something.
Should 3&4 be 3&6?
Re: Cat5 Wiring
Should 3&4 be 3&6?
Yes. Typo. My bad! I will edit the above so that others that look don't end up wiring it wrong.
Re: Cat5 Wiring
Glad you mentioned it Wes :lol: Didn't want to post just incase it was right and i was being stupid :lol:
p.s Pat get to bed earlier (3.49am) stop waiting for television x to start :lol:
