Page 1 of 2
Race Tech Dash2 Config Files Pack HERE
Posted: Wed May 19, 2010 10:26 pm
by Ryan.g
Hi all
Here is the config pack for the Dash2
In the zip file you have:
Can adaptor flash file
Basic Dash2 config file
Syvecs cal file with Custom can bus data to match can adaptor config - PasteCal all Can stuff into your map
See attached
Ryan
Re: Race Tech Dash2 Config Files Pack HERE
Posted: Thu May 20, 2010 2:23 pm
by Ryan.g
Found a slight error with the frame content on one of the sensors and now updated within the package above
Ryan
Posted: Fri May 28, 2010 4:08 pm
by Wez
Top stuff matey, I was going to call you about these bits and pieces
Posted: Sat Feb 18, 2012 12:04 am
by wrxbart
Hi tried to load your file onto my dash2 but it only gets to 99% then stops and the dash then goes into a fail mode with no back light and only parts of the dash working. You then have to do a dash 2 reflag with the original software to get it back to standard again. Any help available to sort this?
Posted: Sat Feb 18, 2012 10:38 am
by Ryan.g
Hi Bart,
This must be an issue with the new Dash2 config software.
I would suggest speaking to Lorne at Race Technologies and send him config file
Ryan
Posted: Sat Feb 18, 2012 1:45 pm
by wrxbart
Ok many thanks mate will do.
Posted: Tue May 08, 2012 2:51 pm
by tarmac terror
Has this now been resolved??
TT
Posted: Wed May 09, 2012 2:04 am
by Ryan.g
Yes Lorne has updated so you can select Syvecs on software now.
Posted: Tue Jul 02, 2013 11:12 am
by ders
Any information on how this interface will work with the new Dash 2 Pro, which is touting a direct 1M CAN interface? Or will we have to sit and wait for the 'comming soon' to be formally elaborated on by RT?
Posted: Tue Jul 02, 2013 9:37 pm
by pavlo
It's easy. The new range of RT stuff is great, and the current software a quantum leap in terms of speed.
The new system means just unlock 15 CAN channels and configure them in the same way as you used to with can->serial adaptor. The Syvecs also outputs direct RT serial stream too.
The Dash 2 Pro is based on the new DL1 processor platform so some of the stuff is taking a little while to get ported over, but it's all coming along nicely, I spoke to Martin at RT a few days ago and they marching on with all that stuff.
