CCL disable @idle
Posted: Wed Apr 21, 2010 9:21 am
Is it possible to disable closed loop lamdba at idle only?
I have nice stable and very close to stoichiometric idle with CCL enabled (wideband). However, I'd like to run it leaner (e.g. 15-16 AFR) at idle and possibly cruise in order to improve my city cycle mileage. I get pretty nice results if I disable CCL globally or if set correction amount to zero. Unfortunately I can hardly stabilize it if I enable CCL and target lean AFR, especially after a blip.
Thanks!
Thanks!
