Loom Multiway Connectors. Mil Spec?
Posted: Tue Mar 09, 2010 3:05 pm
by giblets
I'd like to simplify the removal of the engine and loom by using some multiway connectors through the bulkhead. I'd like to be able to remove the engine complete with loom, rather than unplug all the sensors, injectors, etc.
Mil-spec connectors are probably overkill, but does anyone have a supplier/suggestion?
Re: Loom Multiway Connectors. Mil Spec?
Posted: Wed Mar 10, 2010 6:48 pm
by fortran
Militar connectors are the safest, the last think you want is having false contacts in your signals/output they can drive you crazy! You can find decent connectors form RS
http://uk.rs-online.com/web/search/sear ... breadCrumb
or VERY cheap from Ebay (chinese quality as usual)
http://cgi.ebay.co.uk/Military-65-Pin-H ... 829wt_1167
Posted: Thu Mar 11, 2010 5:04 pm
by Sam@TDi
http://www.deutsch.net/deutsch-product- ... spx?page=3
Big investment but a good investment if your serious about using the car.
Posted: Fri Mar 19, 2010 12:01 pm
by TLicense
An alternative to Deutsche Autosport connectors. Equally as pricey though...
http://www.lemo.com/defaultwidgets.asp? ... e=&myPage=
Posted: Sat Oct 30, 2010 10:40 pm
by Rascal Turbo
From long term experience of engine loom construction , the best bulkhead connection is NO connector.
Use a large grommet.
The mechanical vibration from the chassis into a chassis mount type connector on each pin / socket is something you do not want to engineer in, its quicker to construct the loom and each wire has 3 less mechanical joints, the reliability increases, and the cost of construction is less.
