Use Sview Math to Invert the output of a channel
Posted: Mon Mar 11, 2024 8:57 pm
by EOG
Hi guys, I understand "wg3maperrpct1" essentially outputs the invert of what its actually doing, so I was wondering if anyone could point me in the direction of how to build a math channel to flip the sign from negative to positive or visa versa. I was trying to figure out out how to get the channel to output -1 multiplied by the wg3maperrpct1 but was unsuccessful. Any help is appreciated!
Re: Use Sview Math to Invert the output of a channel
Posted: Wed May 15, 2024 11:17 am
by alijen
I would like to invert a channel using PicoScope for Linux but can't figure out how to do it.
color blind test
Posted: Thu Apr 10, 2025 5:08 am
by ismchervil
Geometry Dash Lite wrote: ↑
Yup, flipping the sign is usually just a matter of multiplying by -1, but some systems are picky with syntax.
by ismchervil
If a direct -1 * wg3maperrpct1 isn’t working, you might be able to do it through a custom function or expression block depending on the tools you’re using.
