VDO speed sensor
Posted: Thu Nov 26, 2009 5:57 pm
by Nelly
I've just received the S6GP to control a M.Y.07 Wrx DBW engine,
will a VDO 340 020 D inductive sensor work as a speed sensor with this?
I can't use a standard sensor as the engine is mated to a porsche 911 transaxle and not in a scooby ;)
Any help will be much appreciated.
Re: VDO speed sensor
Posted: Thu Nov 26, 2009 11:10 pm
by Ryan.g
Sounds like an interesting project :mrgreen:
You can use the Inductive sensor no problem but you will have to wire it into one of the spare Bi-Polar inputs.
Then assign the AN input used to the Vehicle speed (radar) in the I/O Config.
After that is just a case of setting it up in the sensor window
Ryan
Posted: Fri Nov 27, 2009 3:32 pm
by Nelly
Thanks for the quick reply but unfortunatly i'm new to this and its gone straight over my head :?
I think Pat is making up my loom adapter through Mark at Lateral Performance, is this something that can be wired into the adapter before i receive it?
Or do i need to contact him directly?
Thanks in advance for any help,
Neil.
Posted: Mon Nov 30, 2009 1:48 pm
by Ryan.g
If you are having a loom adaptor made then im sure it can be modified to provide flying leads for connecting the VDO up.
Best to speak to pat about this though
Ryan
Posted: Tue Dec 01, 2009 10:51 pm
Nelly,
If you want anything breaking out of the OEM plugs then let me know. I am making the loom adapter for you, and I'de rather get it right first time rather than re-wire it to suit your application, if you know what I mean. Perhaps if you want to give me a heads up on what you actually have and what you need to connect then I'll stand a fair chance of making it the way you want it :) Feel free to PM me if you don't fancy posting the details up in public...
