Tiny dash battery warning low during ignition on and start-up
Posted: Mon Jan 01, 2024 2:02 pm
Hello,
I have an issue with my Tiny dash, the battery voltage low warning keeps popping up during ignition on (and also sometimes during start-up).
During the ignition on part the battery voltage level is even above the minimum voltage value I set in the Tiny dash.
Only if I set the voltage low alarm back to default it doesn't trigger the alarm.
The battery low level is set to: 11V and I use firmware version 1.17 but the older version had the same issue.
Is this a software bug of did I misconfigure my unit?
Also is it possible to add a delay time (like the oil pressure warning) so during start-up if the voltage dips below the threshold it won't trigger an alarm?
Best regards!
Dennis
P.s. best wishes for 2024!
Best regards!
Dennis
