Hi guys, I have datalogging enabled on all cal switches, and it starts at 2500RPM as expected but does not stop below 2000RPM (and when off throttle)
Can you look and see if you can find my error?
Log continually: no
Log when syncstate is not stop: no
datalogging start speed: 2500
datalogging stop speed: 2000
datalogging start throttle: 50%
datalogging stop throttle: 40%
datalogging start speed: 0
datalogging stop speed: 300
datalogging stop timeout: 5000ms
Thanks for any advice!
Datalogging not stopping
Re: Datalogging not stopping
set start stop speed the same ?
Play with the numbers, open a gauge "logging active", and set the thresholds so you can trigger the logging at idle speeds to see how they all interact, start stop.
Will do, car is remote so not always able to go live.
My understanding from most logging programs is start speed 2500 will start it above 2500, and stop it below 2000, after its below 2000 for the delay period.
What you have should be working ok.
So can't really think why it is not.
Was this ever resolved? It's an unusual fault, would be good to know what caused it.
