Is my Lambda being used?
Posted: Tue May 30, 2023 11:25 am
I'm trying to learn and understand how my ECU and subsequent map has been configured.
The Lambda is narrow band and shows as connected, but I am only 99% sure it isn't being used for corrections in any point in the calibration.
My reasoning, is under: Run-mode Fuelling/Corrections/Closed Loop Lambda/Overall Enable is set to Disabled
with this disabled, I believe the lambda readings are not used to determine any fuelling, no matter what the CAL switch etc is set to.
Is this theory correct? or can it be overridden on an individual basis somewhere else in the config?
Thanks for any help.
