2jz engine coolant temperature multiplier?
Posted: Sun Dec 18, 2022 7:23 pm
Hello to all
I have some problem with cold start when external temperature is low (say about 0 C degree).
Engine always misfire - do not run on all cylinders.
Usually it ending with remove flooded sparkplugs and warming it on fire.
When it start.
When weather is not cold (say above +10 C degree when coldstart is normal)
I suspecting that maybe engine coolant temperature multiplier is not properly set for cold weather?
It looks as:
C degree/value
-30 = 2.0061
-20 = 2.0061
-10 = 1.97583
0 = 1.94531
10 = 1.91504
20 = 1.875
30 = 1.7478
40 = 1.62085
50 = 1.49341
60 = 1.37769
Not sure for 2jz gte vvti that multiplier sould be as high?
Injectors are 731cc petrol only, relative fuel pressure is 3 Bar all the time.
Thanks for advice
best wishes
Jerry
When it start.
It looks as:
C degree/value
-30 = 2.0061
-20 = 2.0061
-10 = 1.97583
0 = 1.94531
10 = 1.91504
20 = 1.875
30 = 1.7478
40 = 1.62085
50 = 1.49341
60 = 1.37769
Thanks for advice
best wishes
Jerry
