Newbie slight issue
Posted: Sat Oct 08, 2022 5:17 pm
by Steve_Rs
High guys new to the forum.
Im Running Syvecs with toucan on my Focus Rs mk2.
I changed air filter to a Group A which is bigger than the one I had on.
Anyway fitted the Group A and was OK till i reved it a couple of times and then it cut out.
Decided to refit the filter it had on from the start, and noticed on the toucan it seems to be on the pop and bang map, when I try and change maps it cuts out.
On first click before ignition it shows med boost map but on start up it's on pop and bang map.
Any ideas guys? Thinking it might reset when I start from cold hopefully. :!:
Re: Newbie slight issue
Posted: Sat Oct 08, 2022 5:57 pm
Presumably more has been tampered with than just changing an air filter then ?
how do you change maps ? Toucan or a switch ?
Are you saying it does not change to the Cal you think it is ?
And pops and bangs...why oh why..
Posted: Sat Oct 08, 2022 6:03 pm
by Steve_Rs
Yeah toucan mate to change maps. I'm thinking more air with bigger filter.
Was fine before changing the filter tbh
Posted: Sat Oct 08, 2022 6:10 pm
And it is not fine after you changed it back.
The air filter is not the problem. Something, likely wiring you have disturbed when doing that is more likely the problem
And you seem to indicate it is not selecting calibrations correctly, but full clarification is lacking.
Posted: Sun Oct 09, 2022 3:52 pm
by Steve_Rs
Think I've sorted it, it seemed to be in Valet mode on start up . Had it on med boost 2 and high boost and seems fine
Just glad it seems OK, as the saying goes if it ain't broke leave it the fook alone 😂😂
Posted: Sun Oct 09, 2022 5:08 pm
Steve_Rs wrote: ↑Sun Oct 09, 2022 3:52 pm Just glad it seems OK, as the saying goes if it ain't broke leave it the fook alone 😂😂
Sound advice.
Posted: Mon Nov 06, 2023 8:19 am
by rcaliole
Steve_Rs wrote: ↑Sun Oct 09, 2022 3:52 pm Think I've sorted it, it seemed to be in Valet mode on start up . Had it on med boost 2 and high boost and seems fine
Just glad it seems OK, as the saying goes if it ain't brokebasketball stars leave it the fook alone 😂😂
Thanks for your advice.
