Latest Firmware Releases
Posted: Tue Oct 12, 2021 8:40 am
by Ryan.g
This thread is for tracking the firmware builds of the AWD Porsche 991 units. When a new release is available it will be added to the end of this thread.
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
Any further Questions please E-mail
support@syvecs.co.uk or speak to your nearest dealer
1.18 Firmware
Posted: Tue Oct 12, 2021 8:41 am
by Ryan.g
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press
C,
F inside a map
Please ensure you are using the Latest Ssuite software which has USB support -
http://www.syvecs.com/forum/viewtopic.php?f=8&t=122
Firmware Version 1.18 -
www.syvecs.com/downloads/AWD_Porsche_997_1-18-1.enc
1.21 Firmware
Posted: Thu Nov 04, 2021 5:46 am
by Ryan.g
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 -
www.syvecs.com/downloads/AWD_Porsche_997_1-21-1.enc
1.23 Firmware - X4
Posted: Wed Jul 13, 2022 2:22 pm
by Ryan.g
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/AWD_Porsche_997_1-23-1.enc
NEW BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-23-1.enc
1.23.3
Posted: Thu Aug 11, 2022 9:14 am
by Ryan.g
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/AWD_Porsche_997_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-23-3.enc
1.24
Posted: Fri Nov 25, 2022 12:09 pm
by Ryan.g
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/AWD_Porsche_997_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-24-4.enc
1.25
Posted: Fri Apr 07, 2023 6:56 pm
by Ryan.g
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/AWD_Porsche_997_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-25-1.enc
Re: Latest Firmware Releases
Posted: Fri Dec 15, 2023 5:17 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/AWD_Porsche_997_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 3:01 pm
by Ryan.g
Changes since 1.27.1:
* Usb Datalogging
* Added 996 option to 997 controller (Set CarCode to 3)
* Programming Fix
OLD BOARD - Firmware Version 1.29.1 -
www.syvecs.com/downloads/AWD_Porsche_997_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 -
www.syvecs.com/downloads/X4AWD_Porsche_997_1-29-1.enc
