Hello,
Has anyone or is it possible to setup a Grayhill brand canbus keypad with canopen eg a 6 button style to be connected into a syvecs ecu S7 can to operate, pushbutton functions like:
logging on/off
different boost levels
rolling antilag momentary switch
cal map selections
traction control levels
Re: Grayhill Canbus Keypad
Posted: Thu Jul 15, 2021 12:28 pm
by Syvecs Ed
We can support these through custom firmware. You'd need to contact support.
Posted: Thu Jul 15, 2021 1:05 pm
by torana
Sounds good,
Trying to do it without using a pdu
Posted: Fri Aug 13, 2021 2:19 pm
by pavlo
You don' t need custom firmware to do this. You can reprogram the keypad to send data in a format the S7 or above can read on custom can import.
Posted: Wed Aug 25, 2021 6:47 am
by Lqqk
Is there any more information on how to do this? I’m looking to do the same.
Posted: Fri Mar 04, 2022 6:26 pm
by audpwr1
Bringing this to the top.
I want to run a 15 position keypad in line with a S7i (new) and Pdu X3.
Does this work pretty seamlessly? Can I make the interaction of one button work on both units (button - 3 way Radiator On/OFF/ECU controlled). This would require both the ECM and the PDU seeing this and using logic
Posted: Fri Mar 04, 2022 8:35 pm
audpwr1 wrote: Fri Mar 04, 2022 6:26 pm
