S6 / ECU Master CAN, Help please
adbex1
Post by adbex1 »
Gents,
I have an S6 and I am trying to set up the can bus for an ecu master PMU and ADU dashboard. The ecu master software comes with a config file that is for Syvecs/life racing, I have installed this on the PMU and dash and set up the S6. This is the first can set up I have done but I think the S6 is set correctly.
The ecu master stuff talks o.k. on the bus but there is no data received from the S6 at all. One thing I’m not sure about is what bus speed the S6 runs at?
Screen shots of the set up below, if someone more learned than me could have a look and confirm that is correct that would be great.
Many thanks.
https://www.dropbox.com/s/mhf714ilbp5z2 ... 9.png?dl=0
https://www.dropbox.com/s/sgcbkc1vrqjdc ... 9.png?dl=0
https://www.dropbox.com/s/54aer6kqdegb6 ... 9.png?dl=0
https://www.dropbox.com/s/hilr8oxcgvx4r ... 9.png?dl=0
https://www.dropbox.com/s/duhln8eb01i3o ... 9.png?dl=0
https://www.dropbox.com/s/s4fi4ujdklvmg ... 9.png?dl=0
Syvecs Ed
Re: S6 / ECU Master CAN, Help please
Post by Syvecs Ed »
Not used the PMU or the ADU but the can speed on the S6 runs at the maximum permissible 1Mbit/sec. The Syvecs CFG looks ok.
