Latest Base Map
Posted: Thu Mar 11, 2021 10:22 am
by Ryan.g
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
1.15
Posted: Tue Apr 27, 2021 2:18 pm
by Ryan.g
1.15 Firmware Base Map
1.18
Posted: Tue Oct 12, 2021 8:44 am
by Ryan.g
1.21 Base Map
Posted: Thu Nov 04, 2021 5:50 am
by Ryan.g
For use with 1.21 Firmware
1.23 Base Maps
Posted: Wed Jul 13, 2022 2:45 pm
by Ryan.g
For use with 1.23 Firmwares
1.24 Base Maps
Posted: Fri Nov 25, 2022 12:12 pm
by Ryan.g
For use with 1.24 Firmwares
1.25
Posted: Fri Apr 07, 2023 7:04 pm
by Ryan.g
Re: Latest Base Map
Posted: Fri Dec 15, 2023 5:51 am
by Ryan.g
For use with 1.27 Firmwares
Re: Latest Base Map
Posted: Mon Apr 15, 2024 2:57 pm
by Ryan.g
For use with 1.28 Firmwares
Re: Latest Base Map
Posted: Fri Apr 19, 2024 1:07 pm
by Ryan.g
For use with 1.29 Firmwares
