Mark_r33 wrote:This ECU must be worth a punt if I find you here too, Peter!
Would you mind elaborating in open forum on the WM control? I, for one, would be very interested to learn about it.
I assume the 50 is your recommendation of a 50/50 mix of Meth and H2O?
I like Stevie and Pavlo's method of ECU control so far, sounds more controllable and as though it would atomise better than PWM pump control and a fixed nozzle.
These ECU's are great, preferred over Pectel, I only went with the MQ12 cause I got it new/cheap of someone who could not use it. I rekon Syvecs should swap/sponsor me a new S12 for it
since its better suited to rotary engine applicaitons.
Happy to share on WI knowledge (hope its not too boring for people)??? remember mine is my own knowledge base since 1995 when I first started running such systems.
I run WM50 (50% methanol 50% water) by mass.
I use this as it offers the best performance (power output) without knock limitation.
On the WM or water control method, I have found over experience that the amount (so long as you meet the maximum output criteria) is non critical, that is to say that it is ok if you oversupply the qty you need to meet your performance level requirement, so therefore you can over administer the amount you require with little ill effect sans the fluid usage amount which tends to be non critical for drag racers, or short duration events.
So it is totally acceptable in my experience to run a fairly simple system. When combined with a simple delivery method (like a pressurized canister for example) you get a system that will be very good while over injection (on non sequential application) in the mid range of about 15% but correct amount in last 1/3rd of rpm range.
Again the specifics are in the detail and understanding of the relationship between excess fuel ration and WM or H20 injectant qty. If you have a good ignition system the window of operation is large and the losses of power are minimal, so if ultimate fluid usage or economy is not a problem for you then you can get away with running a technically very simple system indeed.
I've supplied such systems to people for a long time now and the proof is in their results and reliability. Note: it is very easy to use the 'simple' method and drive it off a PWM and 'map it' some chose to do this, though in most cases it is not required, some applications need this fine tuning though. Also worth metioning this system applies only to pre turbo injection location, which I only use for various performance reasons, I don not believe is injection in the manifold, I have never measured a consistent performance gain (VBOX3i analysis) when using other than pre turbo location, so I dropped that line of development and stuck with the pre turbo location.
