Page 2 of 2
Re: CAN BUS Cal Switch
Posted: Sun Aug 25, 2013 2:46 pm
by Steve
Future Toucan owner here then when this is implemented :)
Hurry up :mrgreen:
Posted: Sun Aug 25, 2013 2:51 pm
Just a few weeks away :)
Posted: Mon Aug 26, 2013 2:26 pm
by Steve
Would this also mean that options like Rolling anti-lag can be controlled by the CAN BUS or is it limited to Up/Down Cal/Trac Commands?
Posted: Mon Aug 26, 2013 2:38 pm
by pavlo
als on/off and rolling als / pit limiter should be doable.
Posted: Mon Aug 26, 2013 2:42 pm
CAL up, CAL down, ALS request and CAL override. First 3 will be in Toucan for sure, hoping to add a CAL override button. Not sure if you can achieve what you need from those 4 things?
Posted: Mon Aug 26, 2013 2:55 pm
by Steve
What would CAL override be used for?
Posted: Mon Aug 26, 2013 3:41 pm
Steve wrote:What would CAL override be used for?
You can configure a specific CAL that is selected while CAL override is active. For example, an "overtake" button that temporarily increases boost compared to the usual CAL.
So anyhing you can set up in a dedicated CAL can be selected at the press of a button, regardless of which CAL you're currently running.
