Logging - doesn't happen.
Re: Logging - doesn't happen.
Will investigate all those points related to logging in due course Paul.
The FP sensor failed giving 0V output. A new sensor is now showing 10bar+ at power up, slowing dropping over minutes as usual (so I know the new sensor is working, although always possible a new sensor is the wrong type or even faulty). I will replace the old mechanical gauge as a sanity check, then dismantle the FPR.
What happens if the log memory is full - does it stop logging, or does it throw away older logs?
If the logging memory is full then it is overwritten. You will only have the last XXX seconds (as shown in SCfg) of logs available, so if you want to record a launch, and you have 422 seconds of logging time then you will need to stop and pull the log within that 422 seconds of the start of the launch.
I am going to guess that you have pulled about 422 seconds of you pootling about some time after your launch experiment.
Can I go and hide under a stone somewhere :oops: :oops: :oops: :oops:
