Page 2 of 5
Re: new to all of this
Posted: Tue Jul 10, 2012 1:21 pm
by hagar
sorry to be a nuisance, i found the 105c cable and the reychem 44 cable but what i couldn't find was shielded reychem 44, have i misunderstood you?
is the analog stuff shielded?
i understand the need to keep the grounds separate for signal and power. is that what you mean by using the right ground in the right place?
Posted: Tue Jul 10, 2012 1:25 pm
Farnell do it, for example:
http://uk.farnell.com/te-connectivity-r ... tt=4176110
Basic "rule" would be that cable screens are power/engine ground whereas 0V feed to (for example) powered sensors, or the signal return of (say) a knock sensor, are analogue ground.
HTH.
Posted: Tue Jul 10, 2012 3:33 pm
by pavlo
Knock sensors also have their own ground separate from the analogue ground.
Posted: Tue Jul 10, 2012 3:48 pm
Absolutely right Paul...I chose a duff, and potentially misleading, example. Thanks for the correction :D
Posted: Thu Jul 12, 2012 9:41 am
by pavlo
No worries TIm!
Posted: Thu Jul 12, 2012 3:40 pm
by hagar
is there an idiot's guide for making your first engine loom or is it trial and error?
Posted: Thu Jul 12, 2012 3:50 pm
by pavlo
Making an engine loom is not something that should be attempted by idiots.
For everyone else, there's Ryan's manual on how to hook up most of it.
Posted: Thu Jul 12, 2012 4:49 pm
by hagar
pavlo wrote:Making an engine loom is not something that should be attempted by idiots.
i do have a hnd in electronics and am qualified to solder on polaris missiles, however it is my first engine loom and i'm pretty sure i am an idiot, what with 42 years of evidence backing me up
Posted: Fri Jul 13, 2012 8:00 pm
Lets hope it doesnt go bang when it's wired up then lol
Posted: Fri Aug 24, 2012 4:12 pm
by hagar
do you use the original ignitor box on the 1jz or do the connections go straight to the ecu?
where is ryans manual?
