Page 2 of 2
Re: Latest Firmware Releases
Posted: Tue Nov 29, 2022 6:57 am
by Slowv10
Hello, I have a huracan 610-4 and am trying to develop a good calibration so I can launch with low 60 foot numbers and not spin . Is there a calibration that you guys have put together that I can work off of ? I am new to exotic tuning and am quite lost on how to calibrate with scal. What should I be changing to get nice solid launches on street tires ? I recently changed my tire size from 305/30/20 to 345/30/20 and I believe the calibrator is confused with that and leaves the car extremely wobbly on top end . If you can send a video or instructions that would be great. Also, can I just save a file that allows me to dyno my car on a rwd roller or do I have to change it every time ? Any info will be greatly appreciated as I am eager to learn how to dial this controller in.
1.25
Posted: Fri Apr 07, 2023 6:56 pm
by Ryan.g
Changes since 1.24.4:
Please ensure you are using the Latest Ssuite software which has USB support -
http://www.syvecs.com/forum/viewtopic.php?f=8&t=122
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
OLD BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/AWD_HuracanR8_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/X4AWD_HuracanR8_1-25-1.enc
Posted: Fri Dec 15, 2023 5:18 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/AWD_HuracanR8_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/X4AWD_HuracanR8_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 3:03 pm
by Ryan.g
Changes since 1.27.1:
* Usb Datalogging
* Only Awd Pressure is read from Hall input if Huracan or 991 AWD build
* Programming fix
OLD BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/AWD_Hu ... 1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
Posted: Tue Oct 22, 2024 2:05 pm
by Ryan.g
Changes since 1.29.1:
* Added AWDTemp Transmission to Gateway
* Enable Speed for Centre Slip Maps
OLD BOARD - Firmware Version 1.31.1 -
https://www.syvecs.com/downloads/AWD_Hu ... 1-31-1.enc
NEW BOARD - Firmware Version 1.31.1 -
https://www.syvecs.com/downloads/X4AWD_ ... 1-31-1.enc
