Version 1.25 is the first release of the CorollaGR Firmware
Firmware Version 1.25 - www.syvecs.com/downloads/X4AWD_Corolla_1-25-1.enc
Latest Firmware Releases
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
Firmware Version 1.27 - www.syvecs.com/downloads/X4AWD_Corolla_1-27-1.enc
1.29 Firmware Release
Changes since 1.27.1:
* USB Datalogging
Firmware Version 1.29 - https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
* USB Datalogging
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 - https://www.syvecs.com/downloads/X4AWD_ ... 1-34-2.enc
Changes since 1.34.1:
* Added AWD Temp Diag CAN Stream for CANCHECKED Dash
Firmware Version 1.35 - https://www.syvecs.com/downloads/X4AWD_ ... 1-35-2.enc
