Latest Base Maps
Latest Base Maps
For use with 1.21 Firmware
- AwdBase_YarisGR 1.21.SC
- (46.26 KiB) Downloaded 3866 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_YarisGR 1.23.SC
- (51.46 KiB) Downloaded 3639 times
- AwdBase_YarisGR 1.23 X4.SC
- (51.46 KiB) Downloaded 3768 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_YarisGR 1.24.SC
- (55.83 KiB) Downloaded 3697 times
- AwdBase_YarisGR 1.24 X4.SC
- (55.78 KiB) Downloaded 3897 times
1.25
- AwdBase_YarisGR 1.25 X4.SC
- (61.05 KiB) Downloaded 4093 times
Re: Latest Base Maps
For use with 1.27 Firmwares
- AwdBase_YarisGR 1.27.SC
- (66.84 KiB) Downloaded 2112 times
- AwdBase_YarisGR 1.27 X4.SC
- (66.87 KiB) Downloaded 2140 times
For use with 1.28 Firmwares
- AwdBase_YarisGR 1.28 X4.SC
- (72.44 KiB) Downloaded 1502 times
1.29 Base map
- AwdBase_YarisGR 1.29.SC
- (72.98 KiB) Downloaded 139 times
- AwdBase_YarisGR 1.29 X4.SC
- (72.89 KiB) Downloaded 1611 times
1.34 Base map
Base maps for Gen1 and Gen2 Yaris AWD 1.34 firmware
- AwdBase_YarisGR 1.34 X4.SC
- (31.31 KiB) Downloaded 775 times
- AwdBase_Yaris24 1.34 X4.SC
- (31.31 KiB) Downloaded 751 times
