Hello Charlie,
Can we create a managed HowTo section which can then be populated with PDF guides?
A few example guide ideas :-
1) ECU Flashing Procedure
2) Using gauges in SCal
3) Comparing calibrations
4) Getting SCal working on Windows7
etc
etc
etc
							HowTo Section
HowTo Section
Re: HowTo Section
Wes,
I guess you didn't spot that there was a MediaWiki install on this machine ?
 I just didn't have much time to do anything with it and it still has the old branding, but if you fancy taking up the challenge then I'll sort you out with access
